Darho
- Cookeville
- Electrician
So concerning the post in facebook about service grounding. If you ground the meter can and rely on the neutral to be the bond jumper between the meter and the disconnect as the diagram illustrates. What happens if by chance you lose your neutral between the meter can and the disconnect? Where does the voltage return to. There is no ground conductor anymore so wouldn’t all grounded metal appliances then become charged by the current seeking to go to ground?
