Stevenfyeager
- United States, Indiana
- electrical contractor
A customer's house service panel is wired as if a sub panel, ie., ground bar is not connected to neutral. Neutral bar is floating. No outside disconnect. No ground rod. Probably the 1956 home was a DIY fuse panel replacement?.... We told the owner, but they are thinking about having us correct it. How dangerous is this ? I did have my worker install a jumper between the ground and neutral bars.
