hhsting
- Glen bunie, md, us
- Junior plan reviewer
Attached sketch shows service rated switchboard fed from local electric utility conductors.
The switch has two main service disconnects in compartment #1 and compartment #2.
I have plans that show each compartment #1 and #2 has neutral to ground bond i.e main bonding jumper.
It is one ul listed assembly switchboard. I find this odd because usually they comply with 250.24(B) exception 1 you have one main bonding jumper for the whole assembly.
Has anyone seem something like below? Can below be done and be compliant with code?
