WCEI
- Central Virginia
- President/Owner, Wayne Cook Electric, Inc.
Reference 230.67 2020NEC
I fully understand these requirements, but I was told by an AHJ, that in addition to this code requirement, that panels are now listed and labeled to have surge protection?
A little background, even though Virginia adopted the 2020 NEC on 1-16-24, the state chose not to mandate enforcement until 1-16-25.
Also, Virginia has an “existing installation” code, that allows replacing equipment, such as panels, without having to upgrade to the current code. So, in this particular case, current GFCI and AF provisions were not mandated, as was a disconnect ahead of the panel.
I believe that the provisions of 230.67 should likewise be exempt. The AHJ said no, because the equipment, (panels), are UL listed to have surge protection, and that requirement can not be waived. I can fully understand that, if in fact, all equipment is now listed this way, that SPD’s are mandatory.
This AHJ is renown for his code knowledge. Therefore, I have little doubt that what he states is not correct. But, I want to hear what you guys have to say. Are panels now listed to have surge protection?
