jetlag
- Eatonton, Georgia
I understand that you cannot run the service thru one bldg into another but I assume the code is not talking about after the service leaves the meter base or outside disconnect on a duplex apartment. I just did new service on a duplex apt . The outside disc s are together on one end and I ran the feeders to the panels up into the attic crawl space and went over the first apt to the second. Was that against code ? It passed inspection but later I started wondering if that was why the original feeders went thru the crawl space under the apts. and not in the attic.
