goldstar
- New Jersey
- Electrical Contractor
Thanks. What did I do, mis-spell something ??? Not out of character for me.I fixed your post.
Thanks. I owe you one. I'll buy you a beer next time I'm in Nebraska.:thumbsup:Note the bold "r" in my quote from you changing safe to safer.
I've known guys that use RX connectors and tape them up knowing that the POCO will be out shortly after they get notified that the service has been upgraded.
Another question is...
What do you guys use when you tape the splices? Do you use 33+ tape first then rubber then another layer of 33? That's what i do but for the rubber tape I like the 3M wraps or I have a roll of wide rubber tape i just cut to size and it covers the whole splice in one shot.
I do similar, but I wrap the first layer of 33+ on backwards, sticky side out, so it is easier to get off later if necessary.
I use these Ilsco P840 connectors. They all install with the same die in my MD6-8 crimper. They are SE rated.
While this post is on these connectors, has anyone experienced a loose connection with these brought on by the freeze thaw cycle. If these connectors are verticle, they will hold water. I have found a few that have the wires pushed out when the water gets cold enough to freeze and thaw a few times.
I have never seen that and find it hard to believe they are sealed well enough to hold water. If water somehow did stay inside I can see it happening though.
Like I said, if the connectors are verticle, they will hold water. It is basically a piece of aluminum that is drilled out on both ends, but not drilled all the way through.
Just trying to let others know it will happen. It is the one thing we look for now if we have irregular voltages, loose neutral, you know...
