My first attempt to use the forum!
For better protection from lightning and high frequency surges, I would like to run a #4 AWG copper grounding electric conductor in the basement of a single family home without using metallic conduit. NEC 2002 Article 250.64 (B) allows this if the conductor is not "exposed to severe physical damage". When referring to #6 AWG copper grounding conductor, the NEC uses "exposed to physical damage". Is there a definition of "exposed to severe physical damage" anywhere?
I know that placing a grounding conductor in a conduit, such as EMT, results in a high impedance for high frequency current. Bonding the conduit and conductor at both ends lowers the impedance, but it is not as good as having no metallic conduit at all.
