Two fold question....... Residential, there is a existing sewage pump with 14 nm to it. It was on a 20 amp breaker.. It was also plugged into a standard receptacle,
I changed the breaker to 15 amp and also changed the receptacle to gfci as it is in an unfinished basement.
Should I have not changed it to gfci and kept it a standard receptacle ???? And should I be ok with the 15 amp breaker??
thank you
thank you
