Shared Grounding Electrode System with separate structure
Greg1707
Alexandria, VA
Business owner Electrical contractor
I am always looking for a way to avoid driving ground rods!
I have a separate structure (workshop with no water) about 20 feet from the house meter/panel.
Can I run a #6 from the panel in the workshop back to the house GES thus avoiding driving two more rods?
what if it is slab on grade with steel which might qualify as a ufer ... perhaps easy if yet to be built?
If you can meet the requirements for a CEE in the footings then you won't need ground rods.
