yes you can, but that's coming up in the sequel.Can't you share a nuetral for two (a) phases if the nuetral is sized sufficiently?
Branch Circuit, Multiwire. A branch circuit that consists of two or more ungrounded conductors that have a voltage between them , and a grounded conductor that has equal voltage between it and each ungrounded conductor of the circuit and that is connected to the neutral or grounded conductor of the system.
Originally posted by hurk27:
[QB] You realize that when you share a neutral between two ungrounded circuits of the same phase it can not be called a multiwire circuit anymore as per the NEC article 100.
and a matter of fact there is no definition of what this circuit would be called?
It does not fit the definition of Multiwire Branch Circuit but it does fit the definition of Branch Circuit.
I do not think there is any code article to stop you from sharing a neutral between conductors of the same phase.
Say two 12 awg ungrounded conductors sharing a 8 awg grounded conductor.
Unusual? Yes.
Practical? Doubt it.
Wayne I am not planing on doing this I am just having some funOriginally posted by hurk27:
Branch Circuit. The circuit conductors between the final overcurrent device protecting the circuit and the outlet(s).
