goldstar
- New Jersey
- Electrical Contractor
Re: Sharing Neutral At Receptacle
You've asked whether both cables are running in parallel and suggested the possibility of EMF issues, but if Bryan's assessment of the wiring configuration is,in fact, correct and there are (2) 12/2 home runs from the JB to the breaker panel, what would be YOUR interpretation of what should be done to make this safe and code compliant ?
Roger, I'm not sure what this thread is about anymore. We've gone from a code violation to EMF issues and using gauss meters to flying frogs and plumbers installing insta-hot water heaters. I thought my answer to Bryan's original question was concise and to the point (at least the way I interpreted the question). However, many of the other respondents also had valid points to the way they interpreted the question. And I certainly don't have a fear of sharing a neutral in a multi-wire branch circuit, but I do have some concerns about DIYers with limited knowledge of electricity landing both of the ungrounded conductors on the same phase.Phil, although this is not what this thread is about, you sound as though you are scared of a Multi-Wire branch circuit.
