TRMElectricianJourneyman
- Oregon
- Electrician
Hello!
My buddy wants (2) 20a circuits in his finished shed for a small work place(computers, musical equipment and a portable AC). The shed is a detached structure, up on pillars. My plan was to run 10ga off of a 30a, 2-Pole(Does this need to be AFCI or GFCI...or both?). The plan was to install (2) GFCI receps and daisy chain through. The inspector is allowing either a subpanel with a main breaker or a disconnect. If I go with the subpanel, NEC requires a main breaker panel for this, which seems like overkill because the only ones I can find locally are 100a or more....again, he only wants (2) circuits. He has no intentions of expanding or selling in the future. Already tried talking him into the bigger panel for future use. no dice.
Question;
If I mount the disconnect; do I still need to drive grounding rods? I was planning to, if he wanted the subpanel, but now that it's a disconnect I'm wondering if it's required.
Question;
