This is for the generator guys. Is there any way to shed back-up heat strips when using a back-up generator when running low voltage wire to the air handler isn't possible? I have used SMM's in the past but with that, it would shut down the back-up heat strips as well as the heat pump itself. I know low voltage wire would be best but if the air handler is on the 2nd floor, it would be nearly impossible to run that wire from the ATS to the second floor without cutting out some drywall possibly.
