- New Jersey
- Journeyman Electrician (retired)
don_resqcapt19 said:From the Gypsum Construction Handbook.
I found the handbook here, but you have to register to see it.Gypsum boards used in the ceiling are not designed to support light fixtures or troffers, air vents or other equipment. Separate supports must be provided.
Don
These guys make it sound as if nothing were ever mounted to a sheetrock ceiling. Sounds like they're trying to indemnify themselves against any potential liability.
There are old work fixtures specifically designed to be supported by sheetrock as well as ceiling boxes intended to support fixtures as well. Here's one such old work box that is designed to hold up to a 20# fixture mounted solely to the ceiling. As you can see it's designed to conform with NEMA standard OS2. I'm also assuming that it has been listed.
http://www.passandseymour.com/pdf/P13.pdf
