Re: Shielded cables for 4160V motor feeders
Look at the change in the exception. The main rule in both 2002 and 2005 says that you must use shielded above 2000 volts. The exception in 2002 premitted non-shielded up to 8000 volts, the exception in 2005 is only up to 2400 volts.
Don
