STHOMAS
- North County San Diego
This is regarding fire alarm/voice notification and fire department communications systems. While it is common knowledge to utilize shielded wire for speaker circuits, and SLC (Signaling Line Circuits) when the SLC are within the same conduit as other (low voltage) circuits to eliminate crosstalk and other interference, the question has come up with how to properly install shielded wire.
First, there are two types of shielded wire. One includes a foil shield around the twisted pair fire alarm cable, and one includes this foil wrap as well as a non-jacketed drain wire intertwined with the rest of the bundle.
I was taught many years ago that in order for the shield to be effective it must be continuous from the first installed device through all installed devices. Additionally, when using shielded wire with a drain, the drain wire must be grounded appropriately per the equipment mfr instructions, typically on one end only, (preferably in the main control panel). Improperly terminating shielded wire results in either creating an antenna and inviting interference, or receiving no benefit from the wire considering the extra money paid for that wire.
Is there a document that explains in general these installation practices with regards to low volt systems, be it fire alarm, paging, two-way communication systems?
Thanks,
Thanks,
