readydave8
re member
- Clarkesville, Georgia
- electrician
Customer felt a shock when unhooking garden hose.  Mobile home, plastic pipe.
I clipped one lead of volt meter to brass hose bib, stuck the other in the ground, never could get over 3 volts. Never could feel with hands. If anything its less than 3 volts since I was using digital multimeter, didn't bother with any impedance because would have made voltage to go down, and I thought it was already low.
I turned off all breakers in outside disconnect, did not affect reading. I told customer it was either an intermittent or one-time event, no reasonable way to fix problem that did not exist at the time I was there.
I know there have been many threads on this subject but am not having much luck finding.
How should I procede? I would'nt mind spending a few hours troubleshooting if I can learn from it, but do not want to start a huge project to solve what is probably a minor issue.
