readydave8
re member
- Clarkesville, Georgia
- electrician
A call today was for shock from air conditioning outdoor unit. I read 10 volts from unit to probe stuck in ground.
Turning off clothes dryer breaker made voltage go away, or leaving breaker on and unplugging clothes dryer.
I expected a reading with ohmeter between either hot prong of dryer plug and ground/neutral prong but showed infinite.
Several times to confirm I unplugged dryer, saw voltage go away, plugged back in, saw it come back, same redundant checks with breaker.
I would have expected the fact that neutral and ground were together at dryer to be contributing factor, must not have anything to do with it since they are still connected when breaker is off.
Any theories?
Any theories?
