Satish Chaparala
New User
- India
I am investigating and analysing the fatal shocks which occured in India due to back feed from battery based standby power home inverters - off line UPS. Some cases of line men working getting shocks due to this are reported. Generally in homes these are single phase inverters off line UPS used as a back up to utility power in homes as the weak utility power fails often in India. In these off load UPS used in homes, only phase wire comes out of the UPS and taken to load through a transfer switch
(change over of supply from utility to UPS. The existing neutral of home wiring is used and the utility side input neutral is connected to the output side neutral inside the UPS. I request you to analyse and tell reasons for back feed and remedies
C. Satish, Life SMIEEE
India
India
