electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
A strut clamp is about 1 5/8 wide.....whatcha gunna do??Hers an example.
I don't like it.
I don't like it.
In order to bond the conduit to the enclosure, the means of securing the conduit to the panel need to have a mechanism that cuts through the paint into the metal. Double lock nuts achieves this. If a ground bushing is listed for this purpose then you'd only need a locknut on the outside.
Sent from my BE2028 using Tapatalk
I wasn't aware we were talking about plastic enclosures lol. In that case you'd need bonding bushings connecting the EMTs together with jumpers.I've always used 4 locknuts on a closed nipple with bonding bushings if before the first means of disconnect and then after the first means of disconnect a closed nipple with 4 locknuts and two plastic pull bushings or when butted up against my enclosure a chase nipple with a locknut and plastic bushing
If there are not enough threads get or make a longer nipple by cutting a longer nipple with band saw and thread files.Thats how I was taught.
Sent from my LM-Q730 using Tapatalk
