apelk
- Houston, TX
I've had people tell me they design lighting on one panel and AC/Heating on its own panel because otherwise load-cycling causes lights to dim up/down. Is this a legitimate concern? Is that actually going to happen, or is it going to happen if there's shoddy workmanship (I've read up on loose neutrals a little bit). The panels are still powered by the same source, so if this was going to happen, wouldn't it happen between panels too?
I can see doing this for buildings where you've got several 277/480V panels anyway due to the large number of loads. Right now I'm designing a building where it's going from installing two panels to three panels if I had a separate lighting panel.
Thanks for expanding my knowledge....
Amy
Amy
