Milton Huei
New User
- US
- Electrical Engineer
I've seen many overhead poles between 13kV and 25kV, most of them use metallic cross arms, some connected to ground, some not.
Since sometimes -most times- the ground soil resistivity parameters around poles i've measured are really not that good (over 1000 Ohms.m typically), i'm quite concerned about connecting those cross arms to ground, and I would prefer to leave them isolated to ground (allowed by 250.110 for >2.5m), or use another less conductive material for the cross arms. So, in case of a fault where those cross arms get energized, that voltage doesn't get transmitted to the terrain where the unsafe ground are.
Exceptions would be lightning arresters, which of course should be kept with their grounding, so I let the cross-arms or other metal hardware at overhead poles be isolated.
Is my concern valid?
Should that cross arm be better isolated from ground and far from users, and reserve ground only for lightning arresters?
Or should that cross arms be grounded so in case of faults any protection at HV substation level get tripped?
Thanks in advance.
Thanks in advance.
