cousinwillie
- Southern Wv
what is this for and where does it go
This situation does not require a shunt trip breaker. In the sub-panel, you don't even need a main breaker (i.e., it could be main lug only). The breaker in the main panel can protect the feeder and the sub-panel, and is sufficient to isolate the sub-panel for maintenance.. . . this sub-panel is going to be . . . upstairs where the bar itself is located and the main panel down stairs. Why would you need a shunt breaker?
They are also used in conjunction with fire alarm systems to shut off elevator motor, heat detector in elevator mech room is wired to shunt trip
i was at a local club in providence RI (the living room)
It's really just an easy way to get the building evacuated. Nobody wants to stay when the music dies.i was at a local club in providence RI (the living room) and the fire alarm went off which in turn activated a shunt trip and turned off all power to the stage. i think that was a new fire code that everyone had to do following the station night club fire.
Shouldn't be any tougher than wiring a typical commercial kitchen system.The RI Fire Alarm Code requires music/dj equipment shutdown upon initiating device activation. It also requires the house lights to come on as well. It makes for some interesting logic trying to figure out what circuits to deactivate and what circuits to turn on.
