How's this one? Do you think it is clarifies it better? Thanks.
No. It does not show how anything works. A person with no clue needs to be able to see
exactly how the circuit is to be wired.
1. The drawing shows a 100a 3ph circuit going thru a contact of a relay ???
John, you have to show the 120vac control circuit going thru an open contact and
then to the coil of the shunt trip and the neutral going to the other side of the coil.
2. You should show the neutral going to the sensors also.
3. You need to give some thought to the EMO, if the EMO is n.o. then the contacts for
the sensors need to be n.c. and the ST n.o.
Give it another shot, I'll check back tomorrow.
