Re: Side-Stepping Corrections for Inspections
To clear up the post I made earlier about the electrical inspector asking the home owner to enter the home and look at the closet light.
After talking to the electrician on the phone tonight what happened was the CO was needed so the electrical inspector passed after the light and switch was removed but the plumbing and building hadn?t passed. When the building inspector did his final he noticed the light and shelves and inquired of the electrical inspector.
The electrical inspector was doing another inspection in the neighborhood and saw the people unloading the truck and stopped. Thus the big deal came down about the light.
Instead of a shelf the home owner had the closet man install wire baskets which would hold clothing. A guaranteed fire in the making. The general contractor called the electrician because the inspector got involved.
Personally I think things like these need to be more closely watched. If the fixture is to close and constitutes a danger of fire then it needs to be removed no matter what the big red book calls for. I mean completely removed where the home owner can not add it back.
Let?s not forget that the code is nothing more than a consensus of the code making panel.
NFPA codes and standards are widely adopted because they are developed using an open, consensus-based process. All NFPA codes and standards are developed and periodically reviewed by more than 5,000 volunteer committee members with a wide range of professional expertise. These volunteers serve on more than 200 technical committees and are overseen by the NFPA Board of Directors, which also appoints a 13-person Standards Council to administer the standards-making activities and regulations.
This information can be found
here and follow these links (Codes and Standards) (Code development process) (How the code process works)
