busman
- Northern Virginia
- Master Electrician / Electrical Engineer
As a follow up to my earlier question about Hardie siding. What about vinyl siding blocks that are installed over existing Gem Boxes. Does the box need to be extended out to the surface of the siding block (usually about an inch) OR can this gap be left open? I looked at 410.13, but I'm not sure the answer is clear. Are siding blocks UL listed as an enclosure?
In the past with this situation, I've used an Arlington BE-1 box extender to enclose the gap. Is this overkill as far as the code is concerned?
Thanks,
Mark
Thanks,
Mark
