hbiss
EC, New York NEC: 2017
- Little Falls, New York NEC: 2017
- EC
I've had two instances in a row now where I had been asked to replace some outside fixtures. Upon removing a fixture it was apparent that a siding guy moved the fixtures some distance from where they were originally installed. In cases like this, the fixtures are always screwed into siding or a "siding block" with sheetrock screws. The wiring is usually extended with scraps of wire (sometimes zip cord) under the siding if it doesn't reach from where the box is and of course there is no ground.
I've also seen these guys put a pry bar behind meter pans to "loosen it up a little" so that they can get their insulation or siding behind it, re-attach service drops with nails and rope, etc.
Tell the homeowner about it and you usually just get something like "it works, doesn't it" or "the guy did a beautiful job, what are you talking about?". Tell them how much I'll have to charge and what I'll have to do to make it right then replace the fixtures and they don't want to hear it.
What can be done about siding guys who do this kind of work? I've pretty much given up since this has been going on forever and nobody seems to be able to do anything about it at least around here. There has to be some accountability.
