Stevenfyeager
- United States, Indiana
- electrical contractor
The parallel trip current threshold is to allow the AFCI to trip instantly at a current which has been moved into the thermal zone in the US to prevent nuisance trips but is in the magnetic zone in comparable European breakers.
The arc signature recognition is not enabled at lower currents because may low current devices generate such signatures in normal operation.
The series arc signature recognition is made much tighter so that it can operate without too much false tripping at low load currents.
But there are problems with a low current series arc signature from one circuit being conducted into another circuit that is above the current threshold. That will nuisance trip a breaker that is not even connected to the offending device.
Just another annoying bit of AFCI lore and history.
I had a new Seimens AFCI breaker constantly trip (new wiring also) A bedroom with an expensive remote ceiling fan with lots of bells and whistles and bedroom LED recessed lights. Tried everything, replacing CB, etc.... Nothing worked. Another electrician in Louisville had the same problem, but I don't know what brand breaker. All new wiring... Finally, after almost the one year warranty ran out, they researched on line and found the lady's brand new Samsung refrig. electronics was not compatible with that brand AFCI. The lady bought a different ref, solved.
