Quick question that's been bothering me, had to install a 30 amp single pole GFCI Siemens breaker the other day, the white pigtail coming off it was a #12 solid. How or why do you suppose Siemens gets away with that on a 30 amp? Suppose they figure the return on the neutral will never see 30 amps? And even if it does that short piece of #12 can handle 30? By contrast I had to install a 30 amp single pole GFCI in a SqD QO panel, and that had a #10 stranded wire attached to it. Just seems sketchy to me and I just don't get why skimp on something like that.
