SimPull Romex-Anyone Have Experience?
Most of my guys run the nm into the box & then "cut up" later w/ a razor knife. It works well for them but when I roughed-in I always removed the sheath 1st for reasons already stated. I see no problem w/ either method.
LarryFine said:
Yes, to me, they do. They do, however, work suprisingly well on UF.
One word of warning: don't cut anything larger or harder, or you'll curl the cutting edges.
Oh, and I always strip cable before inserting into boxes.
I use them on UF also... :smile:
I work blazingly fast. One reason is using a little bit of yellow 77 while installing the romex. Just a little speeds things up a whole lot, and makes even the slick romex go even better. The romex strippers in the picture are the best way to go for speed.
