Joethemechanic
- Hazleton Pa
- Electro-Mechanical Technician. Industrial machinery
I use to lean more heavily towards diesel for that reason. But with diesel you have problems with long term fuel storage. Water gets in the storage tanks due to condensation or some other cause. Anaerobic bacteria lives in the interface and feeds off the fuel. Makes a big mess in the tank and is commonly referred to as "algae". The algae gets in the fuel system and plugs up the filters when the generator runs under load and it kicks out due to low frequency. I find that most don't do the proper maintenance to prevent this. There are companies who specialize in doing this for large storage tanks. It's called "fuel polishing" They add a biocide to the fuel and run it through a filtering process to remove the dead bacteria.Natural gas doesn't seem like the most resilient fuel supply for an emergency backup generator, I'd use diesel.
For myself, I'd still probably use diesel. But for a customer I'd lean more towards propane. Propane in it's tank lasts forever
