electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
I have a group of three buildings, call them A, B, and C, where the owner wants an options standby generator for certain loads (mostly refrigeration). Services are 120/208 3 phase, and generator would be about 150KW. Most of the load is in building A. I am strongly leaning toward a single 400 amp transfer switch in building A and running a feeders from A to B and A to C to pick up the generator loads. I just wanted to check and see if there is anything I might be missing or not thinking about that would point to instead having a separate transfer switch in each building? The service in building A is adequate to run the generator loads in the other two buildings. Thanks for any thoughts!
