storeytime
- Texas
I screwed up. My foreman gave me a material list. I ordered the material wrong.
We put in a 3 phase transformer (480V - 208/120). We only needed single phase on the secondary panel. I should have ordered a single phase transformer with a new 2 Pole breaker for the switch gear that feeds the transformer. I ordered the 3 Pole breaker for the transformer, a 3 phase transformer, and a single phase panel. Don't know how it happened, but it did.
I know it won't be a balanced load on the 3 phase source, but can we just tap 2 phases of the transformer and hit the single phase main breaker on the panel with that. We only need a 1P20 and a 2P20 in the secondary panel.
Second possible problem - The equipment (a pump, about 16A) calls for 20A/230V feed. Now, barring a high source 480 voltage, we will be giving the pump 208 volts. On a pump of that size, is 208 versus 230 volts that critical?
Of course, this problem wasn't caught until everything was mounted, KO's knocked out, conduits in, so any going back to what I should have done in the beginning would be costly.
