BBGigante
- Santiago, Dominican Republic
Hello,
Recently in my worksite we acquired an inverter as back up energy for the offices in case of blackouts (common in my country). The equipment is a TRACE APC6048 Pure Sine Wave inverter which requires 220V input to work properly (according to specs accepts from 194-243V).
The office building is powered from a three phase, Delta-Y 460-208/120V transformer, and what occurred is that when I tried powering the inverter from that 208V three phase system running two lines to the input side of the inverter, the electronics went haywire (I heard a strong rattling sound coming out of the inverter for 2 seconds and then the sound stopped, but the output of the inverter was out of specs, voltage readings were wrong between the L1, L2 and Neutral).
I took the equipment back to the seller and then they told me that it can’t feed it from a three phase system but rather from a single phase system, so I needed to get a special transformer in order to change from 208V line-line voltage from the thee phase transformer to 240V single phase and then input that to the inverter.
Here's a link to a very similar equipment I found:
http://www.extremeheatsolar.co.za/AP-Inverter-owners-Manual-Version-4.0.pdf
Thanks for any reply.
- Has anyone here seen any case like it?
- What difference does it makes for the electronics, being powered from 208V three phase and 240V single phase (given the fact that 208V is within the tolerated range)?
- What type of transformer do you think this "special transformer" is? Scott-T? Open Delta? Any other?
