ctrane
- Jacksonville, Florida
Here is another question that stemmed from the Open Delta High Leg question. I'm pretty sure that if you have 3 phase balanced loads, they are evenly spread across the phases. Example, 9kVA of 3 phase load will put 3kVA on each leg. Does it work this way for single phase loads? Meaning, if you have a 10kVA load across 2 phases of a three phase, 4 wire system, do you get 5kVA per phase of the 2 phases used? Any help will be most appreciated.
