BandGap1.1eV
- East Coast
Long story short, I'm developing a single phase micro grid and have brain damage from all the brick walls I've run into trying to find a solution. I've tried finding a multiport PV/battery inverter but everything on the market is residential sized and will not scale up to the required ~400 kW of PV and 1MWh of battery capacity I need. The one option I found is still in development (6+ months out) but looks promising based on the glossy spec sheet. I also found a smattering of Chinese based options with datasheets in broken english and tech specs that didn't make much sense. I'd rather have a US based supplier so I'm no on call for the next 30 years each time the overseas inverter breaks down.
Option #2 would be to utilize the largest single phase PV inverters I can find (Fronius 15 kW, so far) and then try to find a dedicated battery/grid forming inverter. This search has also proved to be fruitless.
Option #3 involved exploring the use of open delta transformers to allow the use of three phase equipment on my single phase grid but the phase imbalances, harmonics, and kVA losses associated with this configuration quickly ruled it out.
My remaining options involve upgrading the entire single phase grid to a three phase configuration, installing a distributed micrgrid on each residence, or throwing a hail mary in the hopes that someone out there in the ether knows a guy who knows a guy who knows a guy who knows a company that offers a large single phase battery inverter/charger that can be used in a micro grid scenario.
Any takers? 10 internet points available for the first promising response!
