HappElectrician
- Youngtown, AZ, US
Anytime an AHJ inspector tells me something, I just say 'yes sir', esp. when it is something relatively trivial like this thread.
Lol. True.
Sent from my SM-N910V using Tapatalk
Boy you got one moron of a inspector , he did not even plug a tester in. What a useless ......inspector
How do you know if the OP is working in Mass?
Wired a shop a couple of years ago in resident's back yard building. AHJ said must have TR receptacles unless over counter or above 50 inches - a future resident may convert to a day care room or something like that with children as a reason I guess.
You can not go with "What-Ifs" As long as it complies to the NEC and/or the local amendment then you are fine.
I always ask for code reference if he/she can not come up with one then it is not getting changed to their way.
Look at it this way, you get pulled over by a cop and get a ticket that does not have a violated code section and it is only $100. There is no vehicle code section to cite you on but the cop "Thinks" that you did something wrong. Will you pay that ticked or fight it?
The NEC does not require the use of simplex receptacles.
Ask inspector for Code section.
I would be curious to know how many states require the inspector to cite the code reference for violations. I know in Oregon, inspectors are required to do so.
They adopt the document as is or they make amendments, and need to have those amendments included in the statutes, otherwise they are making up requirements as they go. No reference to the code section or the amendment that is in violation is not the right way to do it, though it still does happen in some places.I'm still in my apprenticeship, but this occured to me early on. If I'm correct, cities/jurisdictions choose what codes they adopt. NEC isn't an authority like OSHA. (I could be wrong on this, and would appreciate corrective feed back) So, just quoting code isn't the end of the argument. I think the better angle is arguing how the function of your install satisfies the concerns of his requirements.
Though some places to inspect to the plans/specifications, IMO that should remain between the designer/installer/owner, all the city/state inspectors should be inspecting is for code compliance and not to see if a designers wishes were fulfilled.And, so, my answer was simply that he needs to make sure what the inspector is referencing for this requirement. Because the answer may be outside of what he knows of the NEC.
I have seen inspectors more than once blindside someone with the specs and/or city code. Once, an inspector actuall told us that it was his job to make sure we complied with our contract with the customer, as if he was hired by them or something.
(Don't think I'm one who tries to avoid doing things the right way. I am indeed a professional and work with integrity. And a big part of that is knowing how to navigate the AHJ minefield)
I don't like "what if" inspectors either. So it is a shop today, in 5 years it may be a daycare - shouldn't proper permits be filed at that time and things be brought up to what they need to be then? what if they put livestock in it in a few years or decide to put a swimming pool in that building?Anytime an AHJ inspector tells me something, I just say 'yes sir', esp. when it is something relatively trivial like this thread.
Just said 'yes sir' and swapped out 18 spec grade Hubbel outlets for cheap big box TRs I had on hand - switched back to the Hubbel after permit signoff, did cost me an extra hour or so, did not even wrap the wires on the TR screws as they never ever carried any current.
i am not agreeing with "NEC" being stated in laws and statutes.
closest you will get is local ordinance by way of adoption.
laws typically state that the AHJ will either make and maintain their own code, or adopt something. i have not seen any laws saying "the code to be used is NEC 2014", as example.
but, me all eyes. show me a law or statute that says "NEC" in it.
(1) Primary standards. The following standard is hereby incorporated by reference into this chapter, subject to the modifications specified in this chapter: (a) National Fire Protection Association® (NFPA), One Batterymarch Park, Quincy, MA 02169-7471, telephone 800-344-3555, www.nfpa.org: NFPA 70 National Electrical Code®, (NEC®) - 2011.
Note: Copies of the standard are on file in the offices of the Department and the Legislative Reference Bureau. A copy of the code may be purchased from the organization listed or may be reviewed on the organization's website at not cost if the person is a registered user for the site.
Nebraska puts NEC into the law books also. Every three years the legislature must have a bill go through proper legislation to get the new code entered as the edition that is in effect. In general once passed the law goes in effect 90 days later unless there are emergency clauses - which almost never happens with adopting a new NEC. This year because of timing of legislation the 2017 NEC did not go into effect until Aug 1. In 2008 there was a lot of opposition to the bill, that was the year the AFCI's got expanded even more, plus NE had amended the AFCI requirements before then to basically strike out 210.12 altogether. 2008 was going to include 210.12. It got held up and if I recall correctly we were getting close to time to think about adopting 2011 before 2008 ever got put into law books.NEC books are free online, so any smart phone, hence all NEC books are in you back pocket
having "NEC" in the law verbiage just seems odd to me. so you need a legislation cycle(s) and a vote to have that changed? do they even know what they are voting on?
"at not cost", only if they could spell and/or grammar check
so all of Wisconsin must abide by NEC 2011, no locale can use NEC2014 ?? 316.04(3) allows for it, but if the other code is say less stringent in any area then 316.04(3) does not allow it. this is why i say having it hard-set in the laws is a bad idea.
as for the DW recept, install singles, done. might as well just install singles there from now on, and when mr gadget says "hmmm, you need a duplex there" you'll be ready to go.
this is off-topic, so last one.
as written the Wisconsin law is hypocritical. lets says the 2014 NEC lightens up on some restrictions that were in the 2011 code, for whatever reasons that is, the law says anything else cannot be less restrictive, so how would it even be possible for legislature folks to vote in new code that was less restrictive than the code they had?
IMO, the legislatures should govern the framework by which things are done, hence, the state law should say "a standard is to be created or adopted by the state's [building code enforcement agency]put correct dept here and should be reviewed and updated every 1yr minimum"
this way you dont need state legislature goofing around on something they know little about, etc.
governance is by framework (should be), its the only way to make fluent/efficient govt. state legislature goofing around with having to vote on what NEC version is to be adopted is just a waste of taxpayer $$$.
Well, here's a personal situation I recently went through. I put a gas tankless WH in my garage. It's a UL listed product and the install manual specifically says not to plug into a GFIC or AFCIi outlet. It pulls a whopping 3 amps! There is a duplex GFCI next to it. So I assumed that if I remove that GFIC, I must replace with a single receptacle. Otherwise I leave an non-GFIC receptacle half available for general use in a garage which is not legal.
Make sense?
If its in the Garage there is no exception or a area covered by AFCI you must AFCI.
I don't see a issue with it being on a GFCI. What brand ?
