weressl
Esteemed Member
Psychojohn said:Because the zero crossing point is at the same point in time.
And each leg is in phase with the other, just equal and oposite voltage.
A three phase circuit have its phases 120 degrees apart from each other. The 120/240V system has its phases 180 degrees apart therefore it IS a 2 phase system. Its primary, however, is a single phase source.:roll:
