- New Jersey
- Journeyman Electrician (retired)
Re: Size of 400Amp GEC?
Why separate grounds to each rod? You could use one #6 ground to the first rod and then continue it unbroken to the second rod. Since it's a GEC it must be unbroken.The ohms on your ground rod is only equal to you #6 solid, but you will need 2 ground rods 6' apart without a water ground. Separate grounds to each rod
