R retired Member Nov 7, 2005 #1 13K SINGLE TRANFORMERS TO 480/277 VOLTS 1200 AMP. size TRANSFORMERS ?
steve66 Senior Member Location Illinois Occupation Engineer Nov 7, 2005 #2 Re: SIZE TRAMSFORMERS Voltage * current * sqrt (3) = size. The voltage is line to line. Currrent and voltage should both be RMS, both from the same side of the transformer (use 480V and 1200A). Then add any extra spare capacity that might be prudent. Steve
B bh Member Nov 7, 2005 #3 Re: SIZE TRAMSFORMERS If you want to use single phase transformers use three 333KVA single phase transformers configured delta-wye. 13.800 KV primary delta and 480/277 secondary. These three will give you 1200 amps on the secondary.
R retired Member Nov 30, 2005 #4 Re: SIZE TRAMSFORMERS Thank you for the answer on size transformer! Happy Holidays to all retired
charlie b Moderator Staff member Location Lockport, IL Occupation Semi-Retired Electrical Engineer Nov 30, 2005 #6 Re: SIZE TRAMSFORMERS Originally posted by spsnyder: What about us working stiffs? Click to expand... I think he meant, "Happy Holidays to all. Retired." Click to expand... He missed the period.
