- Massachusetts
suppose the overload device in the unit fails?
How is that at all different from any other circuit we run? :-?
If the OCPD fails on any circuit all bets are off.
Money is never an issue.
Just knowing how to follow an instruction in a book don't make you an Electrician, Just a good follower and worker maybe.
This is one thing in the code book among many I disagree with, and ignore. I use the wire size needed to supply the current necessary for the load and use an OCPD that will protect the wire used. End of story.
Fair enough. I will continue to protect downstream and not upstream. Everyone else can follow the code book if that?s what they are comfortable with.
:smile: Rubber gloves? If I had a problem with in rush curent I would be looking at the load to see why the motor was taking so long to come up to speed.
So am I to expect that you do not install services? The service entrance conductors are not protected from short circuits or ground faults and they are protected from overload conditions on the load end.Fair enough. I will continue to protect downstream and not upstream. Everyone else can follow the code book if that?s what they are comfortable with.
