A guy at the facility where I'm working wants to install finger-safe test jacks in a box nippled to the side of a disconnect switch so that the electricians can perform live-dead-live tests when locking out the disconnect. The disconnect feeds span wires for two overhead bridge cranes and I believe the wiring is 4 AWG. The test jacks would be tapped from the downstream side of the disconnect and I believe that he wants to use 10 AWG or smaller from the tap point to the test jacks. The taps to the test jacks would be less than 2 feet long and would be un-fused. Does the NEC allow taps to test jacks, using wire smaller than the protection of the main feeder, without over-current or short circuit protection of some sort for the smaller wire?
Thanks all.
Thanks all.
