I'm sizing conductors for a 75kva 480/208/120v 3phase 4wire Delta-Wye transformer.
Is the neutral a current carrying conductor ?
4 wire secondary
voltage = 120v
amps = 361A
wire size = 500kcmil THNN 90c
disconnect or ocpd = 500A
I have attempted about three different ways at arriving the correct conductor size taking in
consideration the ampacity, the ocpd, adjustment for current carrying conductors, 75c on
terminations. When do you divide the ampacity by adjustment factor, when do you multiply the ampacity by the adjustment factor.... you can be going along pretty good when "BAM!!
you are lost.... I really need a step by step process to sizing conductors so I can find my way back home... s.o.s s.o.s !!!! es1451
4 wire secondary
voltage = 120v
amps = 361A
