I have a warehouse with the service voltage of 277v/480v. I want to install a 200A 120v/208v sub panel to accommodate radiant heaters. I looked at the chart and I see that a 75KVA transformer is good for 206A. I'm thinking that on the secondary side of the transformer I can pull 3/0 wire to the new sub panel. I'm not sure about sizing on the primary side.
What size circuit breaker and wiring do I install in the stand up section to feed the disconnect? What size fuses in the disconnect? And what size wiring to the primary side of the transformer from the disconnect.
A nod in the proper direction will be greatly appreciated.
