I want to run a 125 amp feeder to an outbuilding. The building with have a on demand water heater with (2) 40 amp 240 volt circuits, (1) 15 amp 240 volt circuit to a ductless mini split system, (1) 20 amp 120 volt circuit for receptacle outlets, and (1) 15 amp 120 volt circuit for lighting. I'm going to use 1/0 aluminum for the hot legs but I'm wondering what the minimum size wire would be required for the neutral since most of the load is going to be 240 volt. Would I be OK just running an #8 copper?
