ibew441dc
sizing of grounding conductor
CHOCHO77
What type of system are we talking about? I'm assuming it is that which is described in 250.24(c). I agree with those who basically said that you wouldn't have a grounding conductor on the line side of the service disconnect. Most service equipment I've seen has the neutral bonded to the case, or the means to bond it. Installing a grounding conductor of the wire type would create parrallel paths for neutral current. And yes you are required to bond one side of a conductive raceway, so the easiest way would be PVC.
hope this was some help
ibew441dc
CHOCHO77
ibew441dc
