ptonsparky
Tom
- EC - retired
Duh...I even read it.The title of the thread says it's a three phase motor.
Similar to hearing but not listening.
Do you mean OL are not built in for 3 phase motors this size?Single phase, yes.
Almost never built in on a general purpose motor. Some OEM's maybe.Do you mean OL are not built in for 3 phase motors this size?
About only ones I have seen were on some agricultural fans of 1 hp and less. Was Klixon bimetal type like you often see on single phase motors. What they do is put it at the wye point connection of the motor windings, then it will work for either voltage in a dual volt motor, on low volts is only in one of the two "wyes" but still gets the job done.I used to work routinely with fractional HP 3 phase motors. I’ve never seen one with integral OL protection.
Lol I sized it at 175%. But I should have mentioned that he needs to size it at 115% or 125%(depending on motor type) for overload.
The Klixxon switch should be all that is needed for overload protection, the fuse is for short circuit/ground fault for the most part if you have the Klixxon switch, but would not need to be selected at any particular setting other than be no more than NEC maximums.You can’t do that. The fuse curve doesn’t match the motor curve. That is why you have two devices. The fuse will either nuisance trip on starting or fail to protect against overloads which are fairly long time events. At best you might get away with a time delay fuse at 150% such as a CC then use a motor with a Klixxon thermal switch.
Kind of a sign of either under sized motor or undersized equipment it is driving as well.The advantage of the Klixxon is they eventually quit working after being reset often enough.
