- Illinois
- retired electrician
Without the effect of harmonics, the grounded conductor current will not exceed that of the phase conductors.I don't know much about NEC rules, but the reason to have a neutral wire the same size as the lines is primarily for 3 phase systems where because of faults or load distribution there could be a situation where loads are not balance between the phases. In an ideal 3 phase system there is no current flowing thru the neutral, but if that system became very unbalance the current flowing thru the neutral could be greater than the phase current thus requiring a full sized neutral.
