sellakc@gmail.com
- Louisville KY
In article 450, sizing of primary and secondary protection for a transformer is based upon voltage and the transformer voltages and rated impedance. If I have a 13.8kV primary/480V secondary transformer that has dual ratings, as in 1500 KVA/1950KVA, depending on whether or not fans are operational and the oil cooler is functional, which transformer-rated current do I use to calculate primary protection? The table is based upon maximum current of the transformer. This transformer has two primary currents listed. Others have multiple ratings based upon cooling classes. Any guidance here? Is it appropriate to just use the maximum current rating as the table in 450 says (in other words, the highest listed on the transformer)?
