Sleeving
Alwayslearningelec
NJ
Estimator
If your running horizontal feeder conduit and there are wall going up would you sleeve or get your conduits in before wall goes up?
Would it matter if it was a CMU block wall or gyp board wall?
You don't have to run the entire conduit run but just insert the size(s) you need. Why bother with a sleeve in that case
CMU wall - follow the masons and have them sawcut and mud around your sleeve.
Sheetrock - Cut it with a hole saw or keyhole saw where needed.
Concrete - Depends on how many walls you have to go through. If several, make a blockout for your conduits, if just a couple walls, use the vacuum on your core drill and make the bores.
